CVT pulley removal help
By aefron88
By SSgt1994
Myron
By Graffy
By Greg Kilgore
Got a 2021 Axis 500.
Manual states 38nm.
Anybody got the answer?
By Robbie Wyre
I'm working on a 2005 Cub Cadet side by side and I'm trying to remove the front two axles. I have a slide hammer puller on the inner joint and with all my strength they will not budge. Anyone have the same issues and is there something I'm missing or a trick of some sort to pull these out? Any suggestions please and thank you.
