I've done a lot of research on that alternative. All things considered it will def cost more to go that route whether you go with motorcycle engine/transmission or car engine/transmission. A big part of the swap to hurdle is providing power to the wheels and what not takes a lot of fabrication. Not to mention the cost of the engine/transmission itself. If you plan on going that route definitely plan on spending some money.
We are going to do a Honda K engine with auto in our Sand viper The stock engine just does not have enough giddyup. We can make extra parts if you are interested. Look at our wcf discusion under long travel on our 1100 sand viper. We will  sell our 1100 engine and trans.
Their is several topics about using the vw trans that is supposed to be the same .I would also call Joyner USA and see if they have one in stock. I will have a transmission and engine available for sale soon.
  • 5 months later...
I do have the 1100 engine in the bug and I plan to swap it out. I would swap your engine out for a Honda D motor for the amount of work you are going to put into your bug  give us a Call at 661 822 8111
    • By boydog40
      thanks guys
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By mark walkom
    • By Xov
