When starting out, if I put it in low gear and don't hold it there until it starts moving forward, it will jump out of gear with loud grinding noise.  Any recommendations?
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By bms stallion owner
    • By Bryan g
    • By dman66
