Mule will not start. Turns over like crazy. Replaced plugs,oil is good.Does have one year old fuel filter. Has one year old filters pretty much throughout. Thinking maybe fuel issue. Any suggestions would be appreciated.
Could just need a good carb cleaning. , take off the fuel lines and blow them out with compressed air  to make sure they're clear.
to test coils, get a inline spark tester, hook the clamp to the plug or other good ground on your mule, and crank the engine, if you dont see the light (or  spark, depending on what tester you get) you have a bad coil.
EDIT
here is the link to the troubleshooting guide for your engine : https://www.kawasaki-engines.eu/umbraco/Surface/downloadFile/Download
if you're getting fuel through to the filter, that means your pump is sucking, take off, or disconnect the fuel lines and  i would spray carb spray or brake cleaner   or compressed air, through the fuel pump to break up any possible blockages.
I found an online manual and read through it, nothing about fuel pump removal, I guess you just have to use common sense or your own judgement to remove it,
is it possible to loosen the bracket and remove it?\
if you could supply a picture that would be good.
    • By Aaron Colona
    • By Ed Michael
      Subaru SxS.mp4
    • By Some random dude
      2015 Hisun 700 Utv
