I am having shifter problems.  The gears are grinding and now it will not go into neutral.  Is it easier to adjust the cables from under the hood or under the bed?  Both are difficult to reach for an old woman.
    • By Paul L
    • By rdborra
    • By Bryan g
    • By downseast
      Hi everyone
