Recently purchased a Massimo Buck 400.  Looking through the manual, its terrible.  Gives you very little to no information on required maintenance.  I have also looked this machine over and apparently it has no oil filter.  The parts diagram shows a screen that I'm assuming needs to be cleaned.  Before I spend $75 on a service manual does anyone know if it is worth having.
  • 1 year later...
@Jken I’m having the sane problem 😩.. I gave a book that was with the purchase but it does not show in detail how to change the oil. I have called Massimo 2 times and they act like it’s no big deal to do this but I’m a woman and I need to look at a picture!!! I was told after the first 25 mikes to do an oil change. I tried to loosen the drain plug today and almost had a breakdown. Called my grandson and he’s going to do it for me
  • 4 months later...
On 2/15/2019 at 5:39 PM, strike250 said:
Contact me, I have the service manual I can give you
562-682-7859
Matt
Hi Matt. I have a Buck 400 with 29 miles on it. It looks like it was built with a defective valve that separated and took out the top half of the engine. Have had it for about a year and a half, and Massimo won't cover any of the damage. Would it be possible to get a copy of any manuals you may have on this model?
Thank you.
Mark
Preaching to the choir dude.....  Mine overheated on its first day in its very first mile after buying it at Tractor Supply.. ..  Tractor Supply and Massimo ignored my requests for help .. It has ben in the shop 6 times by 300 miles!!  You have my sincerest condolences on buying a UTV from the worst company on the planet .. Does yours have the HISUN engine or the LINHAI  engine?
HISUN...I think.
Sorry ...   according to Massimo Motors rep I talked to in Dallas, they dumped HISUN engines a year ago [ his words] because ...THEY ARE JUNK...  now that mine has been repaired properly, it does run well.. but for how long?  Who knows
562-682-7859
Matt
Many thanks to strike250! Great to have response from the good guy here
    • By KWinTX
    • By Gerald Dillman
    • By Chile
      Chile
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a  Dealer provided CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
