Massimo 700 EFI No Spark
calebcobb1994
Check the fault codes, to see them do this:   When fault comes up, the odometer's clock will turn into a number find out the cause with this number; press clock button, then it will turn back to clock mode, and five second later the fault code will show again.
  • 2 years later...
  • 2 years later...
On 6/15/2021 at 10:59 AM, Jake Alexander said:
has anyone figured this out yet?  I am having the same issue.  I have no spark in my massimo warrior 700.  Changed the ignition coil and wire, still no spark.  I cant seem to find a manual for it anywhere I have looked.
Any luck on this? My 2017 warrior 700 same thing!
    • By Goat Quilter
      We pout new belts cleaned engine and carburetor plugs you name it.  Drove down road no problem came back uphill no power won’t go . What’s the issue?
      could it be clutch?
    • By weasel
    • By Goat Quilter
      New belts and engine cleaned and checked carburetor cleaned drove on flat ground fine turned to go up hill lost power wouldn’t go
      Could it be clutch issue??
      so frustrating this thing has been in shop more than used on our farm.
    • By Bobby Courtney
      I have a 2021 Coleman 400utv with 60 miles on it. I bought as project. It’s idled ruff and fouled plugs since it was new. I have removed and cleaned throttle body new injector new idle air valve new oxygen sensor. Installed ngk iridium plug. Starts and run good for about 5 or 6 miles and fouls plug. It runs rich all the time. I’ve done reset on ecu. I’m about to think it’s time to try a new ecu. Anyone please help.
