Check the fault codes, to see them do this:   When fault comes up, the odometer's clock will turn into a number find out the cause with this number; press clock button, then it will turn back to clock mode, and five second later the fault code will show again.
  • 2 years later...
  • 2 years later...
On 6/15/2021 at 10:59 AM, Jake Alexander said:
has anyone figured this out yet?  I am having the same issue.  I have no spark in my massimo warrior 700.  Changed the ignition coil and wire, still no spark.  I cant seem to find a manual for it anywhere I have looked.
Any luck on this? My 2017 warrior 700 same thing!
    • By CapnWalleye
      Greetings All,
    • By Grant
    • By A P
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
