Check the fault codes, to see them do this:   When fault comes up, the odometer's clock will turn into a number find out the cause with this number; press clock button, then it will turn back to clock mode, and five second later the fault code will show again.
  • 2 years later...
has anyone figured this out yet?  I am having the same issue.  I have no spark in my massimo warrior 700.  Changed the ignition coil and wire, still no spark.  I cant seem to find a manual for it anywhere I have looked.
  • 2 years later...
Any luck on this? My 2017 warrior 700 same thing!
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By A P
    • By John M in Louisiana
      Thanks in advance!
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
