New-to-me 2012 CC Volunteer throttle cable broke during the wicked cold snap we had a few weeks ago (upstate NY). It was already a bit sticky, but at least it was usable.
Is it possible to replace it myself, or must I pay to have it hauled 50 miles to the nearest shop?  I can access both ends, but the majority of it is pretty buried from the top and underneath.
Any advice would be appreciated.
more than likely you're going to have to crawl under it,** usually throttle cables run from the pedal through a hole in the lower dash, and underneath the floor.
 What i would do is find the throttle cable at the governor on the engine, and trace it to the pedal, or the other way around so you will know which way to route the new one.... on each end of the cable are little round tabs. They almost look like BB's. usually you have to pull the cable one way or another to slide them out of their keeper hole. usually pry on it with a flathead screwdriver.
here is an online manual for your machine if needed. https://www.manualslib.com/manual/1146500/Cub-Cadet-Volunteer.html?page=1#manual
 i hope this helps some.
** if you cant crawl under it and you have to jack it up,  be sure to support it with jackstands or concrete blocks, in case the jack fails.
  • 1 year later...
Robynn did you change your cable? I just had to replace a fuel pump, filter and regulator... found a websight to order parts just google parts OPengines  had the best prices for what i needed. but still not the cheapest..
 Nath
    • By Tom Gorski
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
    • By Troy C
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
