New-to-me 2012 CC Volunteer throttle cable broke during the wicked cold snap we had a few weeks ago (upstate NY). It was already a bit sticky, but at least it was usable.
Is it possible to replace it myself, or must I pay to have it hauled 50 miles to the nearest shop?  I can access both ends, but the majority of it is pretty buried from the top and underneath.
Any advice would be appreciated.
more than likely you're going to have to crawl under it,** usually throttle cables run from the pedal through a hole in the lower dash, and underneath the floor.
 What i would do is find the throttle cable at the governor on the engine, and trace it to the pedal, or the other way around so you will know which way to route the new one.... on each end of the cable are little round tabs. They almost look like BB's. usually you have to pull the cable one way or another to slide them out of their keeper hole. usually pry on it with a flathead screwdriver.
here is an online manual for your machine if needed. https://www.manualslib.com/manual/1146500/Cub-Cadet-Volunteer.html?page=1#manual
 i hope this helps some.
** if you cant crawl under it and you have to jack it up,  be sure to support it with jackstands or concrete blocks, in case the jack fails.
  • 1 year later...
Robynn did you change your cable? I just had to replace a fuel pump, filter and regulator... found a websight to order parts just google parts OPengines  had the best prices for what i needed. but still not the cheapest..
 Nath
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
    • By Kingfish
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By Browner010
    • By Fordman1
