Kioti mechron power steering
By Matthew Smith
2013 Bennche Bighorn 700 EFI
Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time. Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters? Almost acts like it might be clogged if so.
By TexAcoon
I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
By Jacob E freeman
By owencole15
Massimo 500 will only crank when I jump solenoid with screwdriver cranks right up and runs great. But won’t start with key doesn’t do anything when I turn the key. Only thing it does is power everything as in dash and fuel pump then have to jump solenoid to crank up and drive.
