Hi, I'm getting ready to supercharge my trooper and I'm looking for advice on the setup. So far I have... a AMR500 supercharger, small intercooler, Dolbeck EJK fuel controller and wideband. Looking for any advice on what else I'm going to need and what to expect..Thank you
Thanks! This is exactly the type of thing I'm looking for advice on! Do you know the specs of the one I'll need?  Would it be a 5v 1w? Also from the 1100 service wiring diagram it showed 1 is pressure signal 3 is temperature signal and 4 is ground.. And  the first diagram shows the diode between signal and ground. So I'm guessing the diode  goes between 1&4 and not 1&3 like you Drew on the paper...?
Yes been so long ,5v 1w works ,think your right 1-4 , I also got a field controller from dobeck but I had them max out to 12millisec or the longest pulse available " been couple years hard to remember "
Running a gt15 turbo seems to work fine
Sent from my SM-G930W8 using Tapatalk
Ok cool! Seems I'll be basically replicating something similar to your setup just supercharger instead of Turbo, until I can go megasquirt later like Lenny(hopefullywhen i have more money)!... So if you could run down everything you had to make it work, I'd appreciate it..  Did your dobeck have a  vac/boost line.. Because I've seen ones with it and I have the one without it... Also did you have to go water/meth injection or 100 octane anything like that.. Thanks..
Forgot went to ejk after 1st programmer broke
    • By Nutcase
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By se3388
      Steve.............
