Whiplash UTV Race Round 9
By Xov
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
By BernieG
I could really use some help identifying some disconnected components on a Yard Sport YS400. The first part is this pipe, which comes out of the exhaust port area or the cylinder. It looks like it had a piece of rubber hose on it, but the hose is gone, and I have no idea what it was previously connected to.
The second item is this vacuum valve looking thing. Again only one line is still attached. What is it's function and what other lines should be connected to it?
The last thing is this hose, which exits the side top of the fuel tank (not the fuel line hose) but is not connected to anything
Any help the community could provide would be greatly appreciated. This UTV belongs to a friend, and I am trying to help him get it running correctly for his kids.
By great8redsfan
Okay folks. I have a low power issue. Been like this for a few years. Place I work at bought 3 and all have lost most of the pulling power. They gave them away after local shop worked on one for 3 months and it had great power for about 1 month and then crap. They replaced throttle body, fuel injector, spark plug and IAC motor. Seat belt switches have wires cut and left open so no seat belt warning light anymore. It revs to 6k rpm in neutral but when put in gear and take off in low it just doesn’t seem to want to go anymore. Running 93 octane fuel with Stabil. Any ideas greatly appreciated. I dont have a scan tool but no codes on dash. If held to floor it pops a little and runs almost 5K rpm but if I let off pedal about an inch it smoothed out and revs up to 6k rpm.
By Alex
What's the best sport UTV / SxS? Varius opinions from the Can-Am Maverick to the Polaris RZR. A few videos that do a pretty good job on reviews and offering their thoughts on the best sport UTV / SxS on the market. 😁 Post your thoughts!
