Diesel cub cadet torque converter doesn't shift.  torque converter is stuck in "low".  also doesn't disengage properly at idle.
visual inspect reveals no obvious problem.  looking for advice on troubleshooting.
thx to anyone taking the time to offer advice.
mark in MN
Okay, sounds like your clutch(pulley) isn't disengaging.
Torque converters have centrifugal weights inside them, and the faster the crankshaft spins, the weights sling out and push the moveable pulley, which tightens up the belt, it sounds like your weights or spring, isn't fully releasing.
Usually you have to take it apart, and clean it, and lube it. Or buy a new one.
    • By CapnWalleye
    • By Steve Waldner
    • By TjB
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By Bryan g
      We see a lot of the UT400 with shift problems, not going into gear, popping out of gear, grinding etc. There  is a bulletin Im sure everyone has saw about adjusting shift cable.  That dont always fix it.  I went round n round with coleman  on couple units. We are a Coleman warranty repair center"AFS Small Engine Repair "   I told them shift lever does not have enough travel .  No amount of cable adjustment  will increase travel . I  extended lever with piece on flat  iron by 3/4 of inch .  This gave shifter enough travel to properly engage into gear completely .  Last couple units to come in for this Coleman sent me a modified shift lever, with longer travel . Problem solved! Also , heads up if you get any new unit ,,,go over and check it out,  grease  all zerks, check air filter for being in backwards, check wiring harnesses for rubbing on rotating parts,  brake hose  routing , make sure not touching exhaust .  These are just  few of the more common failures I see .
