I have a 2015 Kawasaki mule 4010 4x4 that wont run more that 5 seconds when the engine is cold and the o2 sensor is plugged in. once I disconnect the sensor it runs and has lots of white smoke out of the exhaust. once it warms up I can plug the o2 sensor in and it will run fine. I swapped the sensor and didn't get any change.
    • By CapnWalleye
    • By ToughLuck
      I've been having misfire issues with my UTV 400 when it gets warm and I've thrown all kinds of parts at it so far with no permanent resolution.  Today I removed the O2 sensor and it is black on the end.  To me that means it's running rich and/or the sensor isn't working.  I replaced the sensor with a new one and will see how it goes I guess.  With EFI, I'm wondering why the sensor would be this way with low hours and mileage?  Is there a way to adjust or lean out fueling on these?  Thanks in advance.
    • By CapnWalleye
