2021 Bobcat uv34xl gas Keeps Overheating
By Xov
By PossumTruck
Greetings,
By Kingfish
By Rainman
I just picked up a 2021 Coleman UT400 and one of the things it needs is a gas cap. I believe it needs the 2021+ version with mail threads. Anybody know where I can get one? Coleman isn't shipping anything out right now. I believe the part number is P315001811400000. The only after market gas caps I see available are before 2021.
By Fordman1
