Pictures
By JOSEPH LAMAR
I have a 2020 axis 500 and I have replaced the TPS twice and the whole throttle body assembly once and still have code 122. I can barely drive the thing. It bucks and surges like crazy
By joynersfuntillitbreaks
so i just picked up a 2008 1100 trooper and iv ordered a few parts for it now and 99% of what i got fits perfect my issue now is my rear wheel hub is stripped out got a new cv and it fits great but i order 2 different hubs from 2 different places now and they are both wrong the spline opening is to small to fit the factory cv shaft and yes the shaft factory part #s are the same paid 250 for an original new replacement if anyone has anything that works to replace the original hub please point me in the right direction
By Kingfish
By Ridge Runner
thanks
Ridgerunner
By Jon Spruill
