Kinarfi, I noticed that too. What you have to do is manually tick the save sent box. When you send a PM at the bottom of the box you type in has a heading "Options" & all you do is tick the add a copy to sent folder. Done.
Cheers Mike
    • By Brett
    • By hdtran
    • By Rizzguy
      Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
      Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
      This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
      After one ride, the rear bolts have disappeared, because how much tension there is on the flex
      And the bolts does not line up at the flange
      Have a video before and after. And they are telling me that it’s my fault because it does not fit
      wtf.!
      What kind of idiotic people are even answering the phones these days.?
      This guy has probably only read a book and never even driven a motorcycle in his life
      Don’t waste your time with this bullshit products
    • By NicholasNWM09
      Hello Everyone,
      COOL NEW Product Alert!
      A company called NEW Wire Marine or NEW Wire has Badass custom panels for UTV, Buggy/Hunting trucks. From Fully wired switch panels with laser etched rockers with backlights in 5 different colors, to just parts like voltmeters, phone, USB and 12 v chargers. Rockers can be printed, or custom laser etched rockers and they even have sleek labeled pushbuttons. They are a first-class company with a great knowledgeable staff and outstanding customer service. Switches are based on 12v or 24v circuits and they also have marine grade wire and connectors, which is perfect for waterproofing your system!
      Go check them out!
      Check out the websites : https://newwiremarine.com/ and https://rockerswitchpros.com
    • By NicholasNWM09
      Hello Everyone, COOL NEW Product Alert! A company called NEW Wire Marine or NEW Wire has Badass custom panels for UTV, Buggy/Hunting trucks. From Fully wired switch panels with laser etched rockers with backlights in 5 different colors, to just parts like voltmeters, phone, USB and 12 v chargers. Rockers can be printed, or custom laser etched rockers and they even have sleek labeled pushbuttons. They are a first-class company with a great knowledgeable staff and outstanding customer service. Switches are based on 12v or 24v circuits and they also have marine grade wire and connectors, which is perfect for waterproofing your system! Go check them out!!!Honda - xxxx - UTV Pioneer - xx'.pdf
