    • By shepdog
      I just picked up a 2009 bmx utv 500, there is a small 'nipple' on the water pump, its barbed like a hose goes on it , where is that little hose Suposed to go?
    • By Hector
      Hello all,
      I got a 2009 T2 and found the wiring on the fuse box that holds the fuel pump and ecu power had a short and was not wired correctly. I wanted to see if anyone could provide a picture of the back of theirs so i can see how it is wired
      thank you
    • By Michael M
      I'm trying to get mine running (Landmaster 2013 BD700 4x4 from Home Depot) and looking for detailed pics or videos of the carb connections like springs locations, vent tubes etc, like exactly what holes which springs go to.
      Also looking for any cross refence parts that might work, like if anyone has tried one of the cheap v-twin 266 carbs that looks like our 2bbl or other parts that work and are much cheaper/easier to find than the old Subaru stuff?
      Rebuild kits for the carbs or individual o-rings etc. Searched everywhere little luck.
      I have disassembled my carb, its in good condition but some of the o-rings are borderline, and it needs new ones.
      I have several o-ring kits with dozens of styles and none fit exactly.
      If my "rebuild" dosent work ill try one of the v-twin carbs and post back here.
      Any help greatly appreciated.
      Thanks Mike
    • By Rick McGill
      So, here's my story. I have a 2009 Hisun 700cc UTV. Started out as a freebie but you know nothing is free. I'm no mechanic but a neighbor is very good with this stuff and he's been doing all the work. I'm just doing all the cosmetic stuff. After replacing rings, piston, gaskets and seals, water pump, etc., he found that a circlip and a roll pin that hold the oil pump shaft in, have fallen off inside the engine at some time in the past. We don't know when or how long it's been driven that way. I got it from another neighbor who only drove it around the neighborhood once in a while. Anyway, the guy working on it thinks maybe we should just scrap the engine and find a replacement. I've heard the Yamaho Rhino 660 is almost a direct fit for the Hisun 700. My question is, "how direct?" Will it drop right into the same motor mounts? Will all the connections match up? Air box? Gearing? Carb? Sensors? This one is not fuel injected. OR-- If it's easier, where could I get a Hisun engine? Thanks in advance for all your input.
    • By Joel Goldsney
      Wasn't sure exactly how to title this thread as I have a few issues with my newly acquired hisun UTV. Hopefully going to consolidate all the issues in one thread.
      I purchased from a guy who  had rebuilt the engine  replaced the fuel pump as well as re-done the front end. He had the unit running and driving when it quit and would not start. He got frustrated and decided no more projects and sold it to me.  Unit is in excellent condition physically.....hardly any scratches on the plastics. All in all its a good unit with the following issues/symptoms
      1) Mis fire and stalling out when revved
      Well as you can see by the title of the first issue I managed to get the unit running.  Seems that the battery was very weak. I charged the unit and it fired up fine.  The engine seems to stutter and misfire when revved and once the unit warms up it stalls out. I think it's a fuel issue as if I give it a shot of ether it starts back up.
      Additional Note: Revving engine in Neutral  seems to cause indication to flicker and occasionally the reverse light comes on  which seems to kick in the reverse rev limiter. Have also hade this happen when driving around. Reverse Light flickers and revs get cut.
      2) Fuel line configuration.
      When he replaced the fuel pump he got creative with the tubing and removed the "small fuel tank"
      (See pictures)
      Not sure  what the purpose of this tank is but would love some pictures of a stock set up so I can  put everything back together correct.
      3) Issues engaging in gear
      The unit seems to have issues going in to gear...I will move the shifter in place  but the gear won't engage and the lights don't indicate correct. It takes a few tries to engage and sometimes it grinds a bit
      4) Rack and pinion slipping
      This problem is probably a simple replacement fix...when turning to the right with the vehicle not moving the steering just slipps and turns without turning the tire. I believe I just need to replace the rack and pinion but if there is something else please let me know.
      Any insight or tips on resolving any of these issues would be much appreciated.
