The Spot
By MISTERTIRE66
Recently inherited 08 joyner renegade r4 800.. seems to be sound mechanically but I cannot find bal joints. Any pone help with other replacement part number please.
By dave pasch
Has anyone trouble shooted this transfer case? Full 12v to switch and case. No action inside case.
Thanks Dave
By mac66
By sxr951
By Ron from the Mitten
I purchased a 2008 Qlink Rodeo 700 a few years ago. I am from Michigan. Anyone know of any local repair shops? I had a dead battery, so I replaced that, started right up, ran the quad down the road, (this was last year), put it in the barn, shut it off. then a couple weeks later, went to go start it again, and nothing. I have power to the dash lights, horn, turn signals, wench etc, but nothing to the starter switch, and I hate electrical crap. Battery still reads 12.x volts.
Any suggestions would be amazing. I've owned it over 2 years, and haven't run 1 tank of gas through it. No time to screw with it, and very frustrated. Hoping someone can offer some advice of value.
