Plumbing parts list.
2 1" x 3/4" x 1" PEX Tee
1 3/4" PEX ball valve
1 1" PEX ball valve
Wide view of the plumbing.
Kilgore.
Well, wife and I went for a ride the other day. She got a little chilly. I stopped and threw the valves so the heater core was open and the bypass was off. About 5 minutes later. The temp idiot light came on but the gauge showed it wasn't over heating. So I quickly pulled over. Turned off heater core and turned the bypass back on. Less than a minute the temp light went off. Tried again and same thing.
So I left the heater core off and bypass on and came on to the house. Then today was checking a few things out. And remembered what Joe Breaux said about the bleed screw at the top of cylinder head. Sure enough there was air there. After burping the thing a few times while running with bypass off and heater core on. It idled fine not over heating. Putting out good heat for about an hour or so.
Turned off for 30ish minutes. Started back up. Within 5 minutes the temp idiot back on. A few revs and it went off. So I'm guessing there's more air around the gooseneck for the head. Guess I'm going the have to let it run, then burp, then off, let cool, burp, run to operating temp, burp, cool, repeat. Until I get no air.
  • Thanks 1
    • By ned
      I have a Kubota RTV -X900 that I recently got from someone that is in good condition.  I'm trying to determine what year it is all to no avail.  I have the 16 digit product identification number and have gone on line to multiple sites with no luck.  The number is A5KB2FDBCFG024444 .  I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit.  Thanks in advance.
    • By staind
      thanks Dan D. aka staind
    • By rsar
    • By SpaceGhost
      My vehicle is (at least not yet) not a UTV, however, it is an ATV, A 2001 Kawasaki Prairie 400.
      BTW, That's Brandy, my former PTS/TBI service dog on the bike. RIP old girl. She's internet famous. Perhaps you've seen her before...
      The reason I'm here is that Arthritis is starting to set into my wounds and my mobility is getting worse. I will be selling the quad bike soon, and going with a SXS, and have selected a Can Am model as the replacement, so I figured I had better get on board a forum somewhere. Just put in for my Guard retirement, and will be very soon looking to get into a Commander 6x6.
      Wouldn't mind having the Limited with the Hvac system, but am really not sure it's worth the extra 10 grand or not. Plus it's 500 pounds heavier, and I prefer the doors off in nice weather. It's so much easier when working in the yard, and so much more fun when on the trail.
      Anyway, I'm here now, so it will help me research more and make up my mind. Plus once I have it, I'll be able to share stories about it and of course, continue to learn more, as it will be my 1st sxs. Still have time before I get my retirement. Takes a good 90 days at least according to the guy I talked to... Typical government efficiency... lol.
    • By allinone
