Plumbing parts list.
2 1" x 3/4" x 1" PEX Tee
1 3/4" PEX ball valve
1 1" PEX ball valve
Wide view of the plumbing.
Kilgore.
Well, wife and I went for a ride the other day. She got a little chilly. I stopped and threw the valves so the heater core was open and the bypass was off. About 5 minutes later. The temp idiot light came on but the gauge showed it wasn't over heating. So I quickly pulled over. Turned off heater core and turned the bypass back on. Less than a minute the temp light went off. Tried again and same thing.
So I left the heater core off and bypass on and came on to the house. Then today was checking a few things out. And remembered what Joe Breaux said about the bleed screw at the top of cylinder head. Sure enough there was air there. After burping the thing a few times while running with bypass off and heater core on. It idled fine not over heating. Putting out good heat for about an hour or so.
Turned off for 30ish minutes. Started back up. Within 5 minutes the temp idiot back on. A few revs and it went off. So I'm guessing there's more air around the gooseneck for the head. Guess I'm going the have to let it run, then burp, then off, let cool, burp, run to operating temp, burp, cool, repeat. Until I get no air.
  • Thanks 1
    • By Lawrence
      Massimo coolant light blinking what does that mean?
    • By shepdog
    • By amiracle40995
      I've never seen the temperature go high on this thing. the fan runs almost all the time even though the sensor is  reading at the very bottom of it's range. ive taken the cylinder head off.  (nothing definitive but maybe a little fuel on top of piston with oil in it.i don't think this has anything to do with my problem )head gasket is 3 layers deep and I noticed some grit that might have been in between layers but nothing to say the head gasket wasn't intact.  black carbon build up on piston. I've looked all over the head for cracks from over heating. I'm about to look again for hairline cracks that are extremely difficult to see. my buddy helping me said to order rings in case they are letting oil pass thru he also said get a new head gasket.. I'm looking at water in oil first and I'm not ordering rings. I haven't checked the oil cooler to see if it's defective yet.  I'm just hoping someone had a similar problem. my only problem so far has been having to change the spark plug every 100 miles with 93 octane run thru it.
    • By Anthony Vigil
      Can anyone tell me how they grease the drivelines ?  Can’t grease the u joints. Do you need to take the driveline off ?
      And are they easy to take off?
