By ned
I have a Kubota RTV -X900 that I recently got from someone that is in good condition. I'm trying to determine what year it is all to no avail. I have the 16 digit product identification number and have gone on line to multiple sites with no luck. The number is A5KB2FDBCFG024444 . I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit. Thanks in advance.
By staind
Looking for information on installing a OBD port or a lite to read codes in ECM.Â
I can not find a OBD port or a lite to read codes on this R2 with 800cc.Â
I have code readers and adapters for most ATV's. From what I've found so far. They don't have a connection for to read codes. I may be wrong. That's why I'm asking.Â
This joyner is the first one I've run across. Well second one in a week. (my neighbors 2 of them) The other was a trooper with the 1100cc chery motor that had been setting for years. After cleaning up the fuse box connections. It runs like a top. Had to replace all gages with aftermarket gages. Water, oil, gas, amp. Only problem one was the water temp using original sending unit. Had to install 150 ohm resistor on the input wire to get it to read correctly + - 5 degrees. Close enough. Gas sending unit was/is for a boat tank 6" tall. All SS so it should last forever.Â
thanks Dan D. aka staind
By rsar
So I finally got my Quad Gear cab enclosure after waiting out the backorder for three months and to say it's been a huge disappointment is a pretty big understatement. I think mostly because I could make it work, if not for one major issue. The windshield is right next to impossible to see out of. It's a real headscratcher because the side and rear windows are okay. It's not high quality 30 or 40 gauge marine vinyl but I have Quad Gear's stand-alone winshield so I knew it wasn't the best in terms of visibility, but definitely doable for the price. Incredibly, the side and rear windows of the cab eclosure are just as clear as the stand-alone windshield. And the windshield on the enclosure is like 50 percent worse than the stand-alone. It's the same company! I don't get it. If it had just been the rear windshield that was that bad I would have kept it. There are some creases and wrinkles here and there, but I've been using the stand-alone windshield for the past three months so it's good enough not to have to shell out $600 plus for the stock hard windshield. I'd put visibility at about 65- 70 percent. The wife hates it though, which is a pretty big negative. In any case, my original plans were to have an upholsterer change the crappy vinyl out for the high quality stuff and I even sent it to a guy who ended up flaking out on me and refusing to do it. He said he didn't want to charge me $400 for something I paid $200 for. Long story, short, I decided to return it and just get the insanely expensive Kawasaki enclosure next winter since the frigid temps here are about to start climbing in a couple weeks anyway. I first put it on just to see how it would look (I took pics of course) and found that it didnt even seal 100 percent and made it drafty inside the cab. So make that two major issues. At least with the stock enclosure everything will be top flight. Doors will be nice too.
By SpaceGhost
My vehicle is (at least not yet) not a UTV, however, it is an ATV, A 2001 Kawasaki Prairie 400.
Â
Â
BTW, That's Brandy, my former PTS/TBI service dog on the bike. RIP old girl. She's internet famous. Perhaps you've seen her before...
Â
Â
The reason I'm here is that Arthritis is starting to set into my wounds and my mobility is getting worse. I will be selling the quad bike soon, and going with a SXS, and have selected a Can Am model as the replacement, so I figured I had better get on board a forum somewhere. Just put in for my Guard retirement, and will be very soon looking to get into a Commander 6x6.
Wouldn't mind having the Limited with the Hvac system, but am really not sure it's worth the extra 10 grand or not. Plus it's 500 pounds heavier, and I prefer the doors off in nice weather. It's so much easier when working in the yard, and so much more fun when on the trail.
Anyway, I'm here now, so it will help me research more and make up my mind. Plus once I have it, I'll be able to share stories about it and of course, continue to learn more, as it will be my 1st sxs. Still have time before I get my retirement. Takes a good 90 days at least according to the guy I talked to... Typical government efficiency... lol.
Â
By allinone
Recently purchased 2nd hand not going Crossfire GT400 (Australian branded name?) 2020 model. Has some issues what would be the best forum to pose questions.
