I have a 2017 Intimidator XD4 800cc 4x4.  It will run great and then it's like it goes into safe mode and only runs on 1 cylinder.  It's not fouling out the plug when it happens.  Some times when I stop and restart it, it works fine.  First I thought it was a spark issue, then a fuel issue, but I feel like it's a short in the wiring some place.
  • Alex changed the title to 2017 Intimidator XD4 800 Check Engine
    • By ToughLuck
    • By Paul L
    • By CapnWalleye
    • By CapnWalleye
    • By Joe Breaux
