Hi all, I am a proud 2008 Joyner Trooper T2 B) owner and look forward to discussing, teaching, and, learning. I have put a ton of aftermarket work into my machine getting it the way I want and will post some pictures and a list of upgrades for all to see.
G'day latch, good to see you over here. I'm sure we could all learn off you and pick up a few pointers yourself. If anybody has not seen what latch73 has done to his Trooper, your in for a treat. He has a very good common sense approach to things, so make sure you have a look at what he has done to his Trooper here that he has just posted http://rides.webshots.com/album/568423471EKuRdU . Welcome latch73
Cheers Mike.
I'm so happy to see you here! I love reading your post!
Cinda
glad to have you on board, posted some pictures of my fuel tank under your pictures today, hope you don"t mind :rolleyes:
No I dont mind. I will have to go and check it out.
Thanks to all for the welcome. I love reading all the Trooper posts and allot of the work I have done on my buggy came from stuff I have learned through the fourms.
    • By Gerald Dillman
    • By Xov
    • By Paul L
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
