KTM’s Tim Farr Continues Winning Streak at Dixieland Speedway
Howdy new member here . My hobby's Rabbit dogs , gamefowl . I'm retired from my real job but I stay busy with the hounds and gamefowl . So to help around the farm I ran across an old 2007 CC Big Country 4x2 to haul feed , water , sprayer and my sorry a$$ .It is in pretty good shape , 781 hrs. good plastic , tires, ect. . But as anything outside and 18 years old it needs seats ! The thing I have found wrong mechically the Diff. Lock Acturtor is broken where it mounts to the bracket ( partly why Im here ) . Hoping someone here can help ! Just my wish list but Id like to find a roll cage and a composit/plastic top for it Im thinking I'll need a donor to salvage these things from ( again partly why Im here ) . If anyone reeds this and has or knows of any of threse parts PLEASE HOLLER !!
Randy
By gwares
Price: 4000 EUR
Everything works and new!
WhatsApp: +33 758 56 21 59
By Xov
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
