Doug Eichner Brings Home WORCS UTV National Championship
By mcraigchr
Howdy y'all,
Craig C.
By bms stallion owner
By Jerrys500
Thanks Jerr
By Browner010
Recently I had an overheating issue on my 2022 Coleman Outfitter 550 (Hisun UT550) and to check to make sure it was fixed I took it out for a ride around the block. After a couple cycles on the LED coolant meter, I took it for a couple mile ride and on my way back I heard a loud metallic snap then a grinding noise. It was still able to move under its own power but very slowly. I was about 2 blocks from the truck so 'I limped it home and up onto the trailer. I know I need to tear it apart and look for what broke, but anyone have a guess as to where to start? I'm seriously getting tired of this damn machine! 750 miles on it and already replaced the belt, wet clutch, primary clutch, clutch roller weights among a few other things. Seriously, this friggin machine has spent more time on the lift than on the road. I thought I bought this new because it was from the owner of a tractor supply, but he registered it under the stores name making me the 2nd owner voiding any and all warranties.
Any Ideas what to look for would be appreciated.
By Mater Help
I have a 2019 Bennche Warrior that I mostly use around my property for odd jobs. I also cruise the neighborhood and make short runs to the local pub and neighbors houses. The exhaust system is super loud. I was hoping to find something that will fit and work that is quieter. I have included a photo of the system that is on the unit now. Any ideas or recommendations?
Second question: Recently, it has become hard to shift from park to any gear if the engine is running. The shifter moves fine if the engine is off. It is almost as if the clutch (no pedal) is not disengaging completely. I have not tried to do anything to correct the condition yet but as it gets increasingly more difficult, I need to do something. Looking for a place to start. Nothing in the service manual that I can find.
Any help will be greatly appreciated,
