Media Update on Rhino Dangers
By Robbie Wyre
Anyone out there have a street legal UTV? Any idea how to get one registered for on highway use?
Thanks in advance
By KimAC
I need a pair of front shocks for a Landpride Treker 4200NT, from 2005? Does anyone know of a good salvage yard - or another source?
-Kim
By diamondjfarm
Thanks.
By Alien10
A while back I was looking at an auction UTV plow and the mounting of it. Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV. I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn. I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place. The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
Anyone ever try this for a front mount? It would be close to this one that is for sale on the net. It is supposed to fit a KFI plow mount.
