I just purchased a used 2023 Massimo warrior UTV SxS 1000mx with 600 miles on it. I didn't even get a full day of riding and the driver's side rear axle broke. I'm pretty sure it was already going bad because we would hear a noise once in a while. I'm wondering if anyone else has had problems with theirs. Also looking for places to buy accessories.
On 11/8/2024 at 6:23 PM, klm said:
Better save your money for repairs not accessories.
Very good advice..we will try to assist with your problems but with anything Massimo the problems are many...speaking from my experience with them.  I should spent the $2k extra for the Honda or CF MOTO
I went to look at a  cf Moto and the guy that worked there said that off the record he wouldn't recommend getting it because of complaints. After further inspection of the warrior we found that the rubber mount bushings had a lot of play and the coil overs were adjusted almost to the top.. After two tries I was finally able to get the right CV axle. Now I have to try to find some good rubber mount bushings. It also feels like the belt got wet so the clutch is a little sketchy. Fortunately I should be able to do the upgrades myself. I appreciate your reply. I'm always willing to get assistance in finding answers.
    • By Edelbrock
      Thoughts?
    • By UTVLover253
      What you love about it
      What frustrates you
      – Adam
    • By Sando
    • By Blair
