The Yamaha Rhino, a hit in the off-road-vehicle market, promises to go "almost anywhere" with an "amazingly high level of comfort and ease." Now, federal safety regulators are investigating the vehicle following reports of some 30 deaths involving it, including those of two young girls last month.
The Rhino also has drawn keen interest from the plaintiffs' bar: Yamaha faces more than 200 lawsuits in state and federal courts, many alleging the Rhino's design is unsafe. Yamaha has settled some but recently beefed up its defense and says it may start to fight rather than settle.
Yamaha stands behind the design of the Rhino, a two-seat vehicle that looks a little like a cross between a golf cart and all-terrain vehicle. The Consumer Product Safety Commission said its investigation of this type of vehicle, which it calls a utility terrain vehicle, or UTV, was prompted by various factors, including the number of accident reports and the lawsuits. The Rhino is at the center of its investigation, people familiar with it said.
The rest of the story can be found at:
Wall Street Journal - U.S. Probes Off-Road Vehicles After a String of Accidents
Yamaha Rhino Pictures and Specifications
Yamaha Rhino Review
View the full article
    • By rev6engines
      Black Friday is here, and we’re excited to give our offroad family 20% off on all parts and kits! Whether you're prepping for new trails or just fine-tuning your rig, we've got what you need to keep rolling. Now Is also a great time to upgrade your sled, winter's coming fast!
      If you have any questions or need help finding the right part, feel free to call, text, or email us. We’re here for you!
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Texjpr
      2002 ranger 500 4x4 stopped running and wouldn't restart. Service manual wiring diagram helped identify the hub safety switch as the culprit. Using jumper wires to bypass  switch allowed the engine to start and run normally. Inspection of switch showed melted epoxy and a strong smell of burnt electrical. Unable to find replacement part either used or new. Is there a work around other than jumper wiring?
    • By Kingfish
    • By Woody77
      UTV MASSIMOREPLACED STATOR WANT start replaced rectifier still want start stator ohms out 5 ohms each leg what could be wrong at this point
