Mil
Go to solution Solved by jimvmcgee,
  • Solution
It was the check engine light on and in the book it is called Mil Light. The guys help me solve the problem, how to get the code and read it, the code was 0031 and that is the o2, it was bad replace it and all is good. Massamo 560 tboss 2023.
    • By Marie
    • By Joseph Sills
