So I just bought a 2012 Wildcat 1000.  When I bought it, it was throwing the code P0500.  I followed suit and replaced the speed trigger and speed sensor.  The speedo and odometer still didn't work.  I went ahead and cleaned all connections including to the LCD gauge.  This past weekend, we rode and at acceleration I continued getting the P0500 code along with C1312.  After riding a couple miles, the speedo starting acting crazy and then all of a sudden worked.  I found after I cut off the machine, on restart, back to the codes until I rode a couple miles.  Any help on how to fix this issue would be greatly appreciated!  Thanks in advance.
      I've been having misfire issues with my UTV 400 when it gets warm and I've thrown all kinds of parts at it so far with no permanent resolution.  Today I removed the O2 sensor and it is black on the end.  To me that means it's running rich and/or the sensor isn't working.  I replaced the sensor with a new one and will see how it goes I guess.  With EFI, I'm wondering why the sensor would be this way with low hours and mileage?  Is there a way to adjust or lean out fueling on these?  Thanks in advance.
    • By aefron88
