i got a 2011 yard sport ys 400 and it 's loading up I had the carb off and cleaned it no it loads up don't  know which way to turn the air idle screw to lean it out
HELP
So I assume it's running rich, which is to much fuel, not enough air.so I would turn the air idle screw out a little bit to lean it.if not, I would call the manufacturer and ask them.
  • 4 years later...
Did you solve the issue? I have a 2012 ys400 and it's doing exactly what you described. I can't find any helpful information online for this thing.
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By SouthernGypsy
    • By JOSEPH LAMAR
    • By dman66
