Found a hole in Front Diff case, its been there a while, gears look fine but bearings are all shot,
Is it more economical to just buy a complete differential or rebearing the current one
Suggestions on where to Find one
I can imagine a new diff would be pricey from Kawasaki. Unless you find a good used one
look up kawasakipartshouse.com order all my parts from them, and usually cheaper than the dealer.
Found a used case, just waiting on bearings and seals,  Sourced out of Canada,  thanks
Is the hanger bearing available anywhere other then Kawasaki  # 92138-0001,  thanks
    • By Cory J
    • By JSwearer
    • By KimAC
      -Kim
    • By Jacob E freeman
    • By Will Sutton
