Hello-
New to the forum so luckily there is some help out there lol. Recently bought a 2008 Joyner 1600cc sand viper and loving it. Took it out and had a little accident with a tree stump lol. The stump hit directly on my passenger side tie rod end and broke the heim joint that connects the tie rod end to the wheel. Does anyone know the size of the adjustable heim joint so I can order one? I am having a hard time sourcing one quickly. I am also guessing since it is an outter tie rod end, that it is LH pitched rather than RH? thanks for any help anyone can provide. This is again for the outter tie rod end heim joint that snapped. Thanks
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Marie
