I just recently picked up a 2006 volunteer.  It is making a grinding noise that seems to be coming from the clutch or around there.  Sounds like a bering going out.  Trans goes into gear good and it drives good just makes the grinding noise at higher rpms and gets loud as soon as you pull you foot of the gas.  Does anyone know what could cause this or what i need to replace? thanks
  • 1 year later...
Hello Alywiski, you might be able to help me.  I have a 2006 cub Cadet with diesel engine.  The diesel went out and would like to replace with a gas engine.  Can you tell me what size and model Kohler engine is in your UTV.  Replacing the diesel engine would run about $7,000.00.  Replacing with a Kohler gas engine may be $3000.00 at the most.
Thanks T Hudson
    • By SkyPilot56
    • By Karlibob
    • By Tom Gorski
    • By Blair
      Greetings All,
