    • By Edelbrock
      Thoughts?
    • By Chucky 1
    • By Rizzguy
      Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
      Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
      This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
      After one ride, the rear bolts have disappeared, because how much tension there is on the flex
      And the bolts does not line up at the flange
      Have a video before and after. And they are telling me that it’s my fault because it does not fit
      wtf.!
      What kind of idiotic people are even answering the phones these days.?
      This guy has probably only read a book and never even driven a motorcycle in his life
      Don’t waste your time with this bullshit products
    • By se3388
      Haven't been on any long rides yet, just 30 minute rides around here. Not a lot of areas close by but I have a 'sticker' so I can ride on county roads. The 'Stealer' took off the bead lock rims and put these rims on and squared the tires. The factory bead locks aren't that good and seems like the bolts around the rim strip out easily. I like these rims better and I don't go anywhere I need bead locks anyway. with a 1000cc engine this thing has plenty of spunk, top speed is 65 mph. This is a 2023 model and the earlier models had a problem with heat in and around the back of the cabin. The exhaust especially the header pipe has been redesigned and seems to help. I like it so far.
      Steve...........
