I've seen those advertise on the net. Seen a guy on YT that installed one. He said they work. But like you, I would like to hear from others before I installed.  They are kinda expensive.
There's a writeup here on how to get into the ECU to read codes and get the engine parameters (parts and software required). From my understanding the ECU also has flash memory that some parameters can be changed and saved. I haven't tried it. If you do let us all know how it goes. Good luck.
    • By KnS
      Hey Team, our issue is not as bad as some I've read here...  We put some songs one a 64GB USB stick, plugged it in and the USB icon is still greyed out and won't let you select.  Any suggestions?  All the songs are in the root directory.  Thanks, Kevin & Shelbie
    • By MikeM1
      2025 axis xs 750 no place to mount license plate and no light for it has anyone fixed this issue
    • By ToughLuck
