Just by the looks, notice the clean and corrosion areas of the tube.  Suggests that the bolt was used with a rubber bushing mount......like a shock of possibly a suspension rubber cushioned A-arm.  My guess is there are  more of them......look for their sisters under there.  If any found, check their torque also so you don't find more down the road.
Yea, was obvious part of it has been somewhere protected from the elements, either inside of a mounting hole, grommet, or a rubber bushing like you mentioned but so far haven't found any holes missing bolts or any bolts that look like it when looking around on the machine.
    • By Greg Kilgore
      I'm 99.9% sure head gasket is blown.
      Don't have coolant in oil. That a good thing. But think coolant is getting in combustion chamber.
      I did compression test.
      Got 120psi walked away. Came back to 105psi 15 minutes later.
      How hard is it to replace?
      https://youtu.be/N31mOtOPuKI?si=nSnuF4-weRU2T10t
      Advise?
    • By johnney
      i have a 2011 hisun ys 400  idles high,once in awhile, runs horrible under load. iv'e put several differant carbs on it , cleaned the gas tank , took off the vaccum fuel pump and put  an
      electric fuel pump.  no change HELP
      this is a carburated engine, but was wondering is there any electrical components that meter the fuel flow,  like  mass air flow senser or something like that could be causing the fuel delivery
      problem.
      ps i have owned this rig since it was new , and haven't had a full  year of flawless riding.
      oh and bought it from menards and told me i was stuck with it.
    • By JDawg
      Help...
      Is there a better performing higher volume injector than what they come with or what is the best replacement for the original?
