12 hours ago, Joe Breaux said:
A tarp?  It will take a fairly large shed to have a big enough door and tall enough. Those tend to be pricey.
I guess, but would like to have something a bit more user friendly and less susceptible to critter invasion and destruction.
I've used what I think is the easiest solution: 2" PVC pipe and the connectors to create 4 legs and the top crossbars and then two tarps laid over 90 degrees from each other. It makes a great shelter and is cheap and easy plus it can be sim,ply taken down and stored for the Summer, if desired.
Any pics?
I like what you did, I did something similar to cover a pool one year.  Also saw this which is very close to the same concept, it's a complete kit, probably a little sturdier and also more expensive.
https://www.harborfreight.com/automotive/automotive-accessories/portable-canopies-garages/10-ft-x-10-ft-portable-shed-63297.html
Yes, very much like that but very basic. No actual door, just lift one end of one tarp. The tarps came from Harbor Freight and were like less than 10 bucks each. The PVC came from Home Depot. Total cost for everything was less than 50 bucks.
Forget about keeping critters out, they will get into just about anything you erect for storage.
Harbor Freight's canopies are where you need to go.  By the time you fiddle around with tarps, pipes, and ways to secure the tarps,  why not just get the canopy that has a roll up door and room for your machine, and other stuff too.
10x10 is $179
10x17 is $229.
You probably spent somewhere around $8,000 to $9,000 for the UTV, buy something to keep the weather off of it.
10x10 is $179
10x17 is $229.
I picked up a 10x17 just in case last weekend that was on sale for $179.
    • By Grant
      Thanks in advance.
