12 hours ago, Joe Breaux said:
A tarp?  It will take a fairly large shed to have a big enough door and tall enough. Those tend to be pricey.
I guess, but would like to have something a bit more user friendly and less susceptible to critter invasion and destruction.
I've used what I think is the easiest solution: 2" PVC pipe and the connectors to create 4 legs and the top crossbars and then two tarps laid over 90 degrees from each other. It makes a great shelter and is cheap and easy plus it can be sim,ply taken down and stored for the Summer, if desired.
Any pics?
Unfortunately, no. It was such a simple setup I didn't take any.
I've since bought an enclosed trailer and my UTV spends the winter (on a trickle charger) in that.
I like what you did, I did something similar to cover a pool one year.  Also saw this which is very close to the same concept, it's a complete kit, probably a little sturdier and also more expensive.
https://www.harborfreight.com/automotive/automotive-accessories/portable-canopies-garages/10-ft-x-10-ft-portable-shed-63297.html
Yes, very much like that but very basic. No actual door, just lift one end of one tarp. The tarps came from Harbor Freight and were like less than 10 bucks each. The PVC came from Home Depot. Total cost for everything was less than 50 bucks.
Forget about keeping critters out, they will get into just about anything you erect for storage.
Harbor Freight's canopies are where you need to go.  By the time you fiddle around with tarps, pipes, and ways to secure the tarps,  why not just get the canopy that has a roll up door and room for your machine, and other stuff too.
10x10 is $179
10x17 is $229.
You probably spent somewhere around $8,000 to $9,000 for the UTV, buy something to keep the weather off of it.
10x10 is $179
10x17 is $229.
I picked up a 10x17 just in case last weekend that was on sale for $179.
    • By Jr Perez
    • By Greg Kilgore
      I'm 99.9% sure head gasket is blown.
      Don't have coolant in oil. That a good thing. But think coolant is getting in combustion chamber.
      I did compression test.
      Got 120psi walked away. Came back to 105psi 15 minutes later.
      How hard is it to replace?
      https://youtu.be/N31mOtOPuKI?si=nSnuF4-weRU2T10t
      Advise?
    • By Rainman
      I want to put a charger/maintainer for my Coleman UT400 for the winter and need to know if it uses a 6v or 12v battery.
      One search online showed a 6v, but another stated 12v..
      I can look at the battery, but after taking the seat out you cannot see the top of the battery without also removing the top plate under the seat and at 8 degrees outside, I'd rather not be out there too long.
      Can anyone verify what volt (6 or 12) the batter is?
      Thanks in advance ...
    • By johnney
      i have a 2011 hisun ys 400  idles high,once in awhile, runs horrible under load. iv'e put several differant carbs on it , cleaned the gas tank , took off the vaccum fuel pump and put  an
      electric fuel pump.  no change HELP
      this is a carburated engine, but was wondering is there any electrical components that meter the fuel flow,  like  mass air flow senser or something like that could be causing the fuel delivery
      problem.
      ps i have owned this rig since it was new , and haven't had a full  year of flawless riding.
      oh and bought it from menards and told me i was stuck with it.
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
