Coleman UT 400 Garage?
By Jr Perez
By Greg Kilgore
I'm 99.9% sure head gasket is blown.
Don't have coolant in oil. That a good thing. But think coolant is getting in combustion chamber.
I did compression test.
Got 120psi walked away. Came back to 105psi 15 minutes later.
How hard is it to replace?
https://youtu.be/N31mOtOPuKI?si=nSnuF4-weRU2T10t
Advise?
By Rainman
I want to put a charger/maintainer for my Coleman UT400 for the winter and need to know if it uses a 6v or 12v battery.
One search online showed a 6v, but another stated 12v..
I can look at the battery, but after taking the seat out you cannot see the top of the battery without also removing the top plate under the seat and at 8 degrees outside, I'd rather not be out there too long.
Can anyone verify what volt (6 or 12) the batter is?
Thanks in advance ...
By johnney
i have a 2011 hisun ys 400 idles high,once in awhile, runs horrible under load. iv'e put several differant carbs on it , cleaned the gas tank , took off the vaccum fuel pump and put an
electric fuel pump. no change HELP
this is a carburated engine, but was wondering is there any electrical components that meter the fuel flow, like mass air flow senser or something like that could be causing the fuel delivery
problem.
ps i have owned this rig since it was new , and haven't had a full year of flawless riding.
oh and bought it from menards and told me i was stuck with it.
By Alien10
