My Hisun 550 (with the Coleman stickers) has a problematic gear shifter.  No release button, but if often will seem to jam especially in moving to reverse. Even when it does work, it is nothing you could describe as smooth.
When it is very stubborn and just won't drop into reverse, I really jam the brake pedal down hard then move to reverse. It seems to work about 90% of the time.  This makes no sense to me but who's to argue when it works most of the time.
These are hastily engineered machines with mediocre quality parts and fitment.   It  may wear in after a while but if it is impossible, get your dealer to adjust it before too long.
44 minutes ago, Alien10 said:
By the way, Welcome to the site!!
Thanks for the welcome, I can't believe how the shifter locks up I talked to Justin Krep about it and he said that's the way they are being cable and not linkage I asked him about adjustments and he said there is none I feel there has to be a reason why and a solution somewhere.
    • By Frank in MI
      Found a NEW 2022 Bighorn 550 DX for $9K.   Any opinions on this machine????
    • By Cory J
    • By hisun junk
    • By JSwearer
    • By Howard Elmore
