2023 massiso T-boss 750 cam sprocket removal
By Greg Kilgore
Got a 2021 Axis 500.
Manual states 38nm.
Anybody got the answer?
By Rick A
By SouthernGypsy
By sxr951
2015 massimo 700.. need cylinder bolt! it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm dont know where to find any ideas? thx
By Texas Rider
Okay guys, this Vector 500 is killing me. Hisun 500cc engine (Chinese) About a year ago while riding slowly, I heard a tink and UTV turned off and would not start. Checked everything long story short, timing chain jumped off lower sprocket, slightly bent the cam sprocket phasers. Bought new chain and cam sprocket, set everything back to timing position, mounted chain on lower shaft sprocket and upper cam sprocket. Set the tensioner, cranked and poof, chain once again jumped off lower shaft sprocket. Again, repeated proper timing settings, remounted chain, cranked and poof again and again and again, chain keeps jumping off lower sprocket. Just to be clear, valves, piston and all components are look in great condition. Can't see shaft sprocket but to the finger behind the tight squeeze, all sprockets seem to be in place, or maybe not. Tired of fiddling with it. This was bought brand new at Home Depot and has less than 200 hrs in the past 3 years. Don't tell me to warranty it as that expired one year in. Talked manufacture out of McKinney TX and service tech was no help. My question to you, what am I missing? What next?
Dumbfounded 🤔
