I bought a "24" 550,my first impression was this thing is noisy,jerky,slow....But after 30 miles i changed the filter and oil to Mobil 1,immediate difference in engine noise,by the time i hit 40ish miles the belt had worn in and alot of the jerkyness stopped on takeoff,and running in low over bumps i was fighting the weak accelerator spring trying to hold steady rpm's so i put a stiffer spring 100% better and use only 93 octane it does not run well on 87.One problem with cabin noise is your sitting on the engine and its inside a big plastic hollow box that amplifies the sound,my next step is to add sound mat inside the box,So at 9k thats about right i paid almost 11k for mine new,bottom line is my father in law likes it over his honda pioneer 700,has more room and independent suspension,adjustable shocks,larger bed,with only 50miles on mine i cant say much on life of the machine but so far im liking it
  • 2 months later...
Recently bought a Bighorn 550B at Tractor Supply. For the money it is equiped like far more expensive($5000-$6000 more) bigger name brands. Overall, I'm well pleased. However, I have noticed some slipping of the CVT belt. I'm hoping this will get better with time as I've only had it a few weeks. Anyone else have this problem?
Hi, when doe the belt slip? Not sure on the Big Horn, but if I'm not driving over 20 mph on my Bad Boy/Hisun I have to stay in low gear for the clutch to fully engage. Good luck with your Big Horn
My Hisun 550 (Coleman Outfitter stickers) does much better running in low gear.  I can get up to about 30mph without going deaf from engine noise and even that is 10mph more than I'd use around my property.
Like Randy said, and I agree, you'll have better full engagement in low and likely less wear as well.   I seldom use High anymore.
    • By Unhappy Kioti K9 Owner
    • By Xov
      Thanks in advance.
    • By A P
    • By Adrian Domingues
      Thanks for your help
