UT 400 Injector Upgrade?
By didgeridoo
By John M in Louisiana
Quick question about replacing the plug. One of the prongs pulled out, so I'm thinking it will be an easy fix to connect the old cord with a new plug but I'm unsure about the specs. 15amp 125v? Is it more complicated than that? I do plan to buy a plug that's water tight.
Thanks in advance!
By Woody77
By hetovi
Hey everyone,
By BuggyBoy
So these Giant 48v/110ah batteries have just become available: https://www.aussiebatteries.com.au/giant-100ah-48v-lithium-golf-cart-deep-cycle-battery
They look like they could drop in either side of the Controller that sits in the middle of the tray as they are 330mm(W) 355(L) 295mm(H). They can be paralleled, and I think two should be enough. Technically once paralleled the system should output 400ah continuous and 800ah Max (5 secs), more than enough for the E1 - probably 1/3rd more than is needed.
However, the sales person stated that if the regen braking exceeded 400amps, it would put the batteries in standby mode for protection and they would have to be 're-started' with a jumper pack to reset them. Does anybody know the max output of the E1 Regen system, and if it does exceed that, is it possible to disable/bypass the regen so it has a zero output?
Thanks.
