I want to put a charger/maintainer for my Coleman UT400 for the winter and need to know if it uses a 6v or 12v battery.
One search online showed a 6v, but another stated 12v..
I can look at the battery, but after taking the seat out you cannot see the top of the battery without also removing the top plate under the seat and at 8 degrees outside, I'd rather not be out there too long.
Can anyone verify what volt (6 or 12) the batter is?
Thanks in advance ...
I'd bet a dollar to a donut that it's 12v. But, to be sure, get a cheap Volt-Ohm meter and measure where you are going to attach the trickle charger. Harbor Freight has them for 5 bucks or so if they are not just giving them away as promos.
      Best way to reset the computer?  Can I just disconnect the battery for a few or do I need to do something else?
    • By Howard Elmore
    • By Jacob E freeman
