2017 Massimo 500 that is locked in 4 wheel drive
Go to solution Solved by TxDoc,
Posted (edited)
Edited by Alex
Updated Title
  • Solution
I don't own this model, but it should have a servo that requires an electric signal to engage and disengage. It may not be getting the correct voltage or any voltage at all. Locate that harness and the plug. Is a voltmeter to see what you're getting
Someone else with this same model and has personal history with it may come along, too
I'm willing to bet it's going to be a simple thing.
Sent from my motorola edge plus 2023 using Tapatalk
  • Alex changed the title to 2017 Massimo 500 that is locked in 4 wheel drive
    • By Tom Gorski
      Just bought a 2014 Volunteer. Can anyone tell me what parts have to come off to change the oil and filter. I can see them but I can't figure out how to access them. Thank You
    • By UTVLover253
      What you love about it
      What frustrates you
      – Adam
    • By Bbicon
      I have a 2014 odes 800 dom. I  have a wire in the same harness as the fuel pump plug ( just before it ) and it is not connected to anything t has a connector and a little brass connector on the end , I was wondering if anyone could tell me where it goes to
