750 Challenger spare tire / wheel
By Jon V
By Qtband
I'm looking at picking up this UTV and this is what the owner says:
"All I know about it is it runs. Display does not work and it will not move! Front end or trans could be locked up. It moves some, but does not sound good."
My question is, what could the moving issue be, and how can I check it out when I look at it? I feel the price is right at $2000, but I'd like to know what I'm getting into.
By onealmck
By Isaac
I have a 2013 odes dominator when I get in it. It ideals fine but when you give it gas it bogs and goes and bogs and won’t go passed 30 can anyone help me
By Buck
My father-in-law has a Hisun 750. It has started to not change gears while running. He can turn it off, change gears, then restart and it will change. I thought it might have something to do with the brake but can’t find any info. Thanks in advance for any info.
